SmartFTP / Smart FTP Ultimate v4.0.123|תוכנה טובה לניהול שרת FTP
2 תגובות לנושא זה
 itaysorin
itaysorin
  • 353 הודעות
    • מונה תודות: 15 תודות
SmartFTP.Client.Ultimate.v4.0.1231.0-DOA
Tested on XP x86 and 7 x64:
תמונה שפורסמה תמונה שפורסמה
NFO:
Code: Select all
                      Dead On Arrival
                        Presentz :
SmartFTP Client Ultimate v4.0.1231.0
size 4x5mb
date 1/26/12
The most popular FTP client for Windows.
Registration : use appropriate files
Note : As usual, block app with fw when registering!
http://www.smartftp.com/
DEAD ON ARRIVAL : we sure acknowledge that what
we do may be questionnable, but considering a lot
of people seem to like our releases (no matter if
they expire or not), we shall keep on releasing
cause it seems our stuff is way more appreciated
than what is usually done scenewide. Now instead
of logging onto your coolest ftpd and grab last
update of some soft nobody gives a ~love~ about, maybe
show your talent in removing the i-net checks of
our apps and/or keygening them. That will be really
useful for everybody!
Today, some apps can't be cracked/keygened the old
way, that's why we're here.
Contax : n/a
Installation instructions:
Code: Select all1. Unpack the archive.
2. Unpack the zip files you get one by one or all together.
3. Unpack from the new .rar file and you'd get the setup file, the license installer and the license file.
4. Install the app using the setup and either use the license installer (SFTPLicenseKey.exe) to install the license or open the app and import the license file manually.
Download link (Three mirrors inside!):
x86:
Code: Select allhttp://safelinking.net/p/1b554d54df
x64:
Code: Select allhttp://safelinking.net/p/40f0f7706c
 DeathMagnetic
DeathMagnetic
  • 94 הודעות
תודה, למרות שכמו כל שאר האשכולות - גם זה מועתק.
