יצא המשחק Max Payne 3 למחשב
68 תגובות לנושא זה
המשחק להורדה ב - http://www.bitgamer.....php?returnto=/
וגם ב - http://www.torrentle.../account/login/
Max Payne 3 RETAIL DVD [NO CRACK] READNFO-P2P
For Max Payne, the tragedies that took his loved ones years ago are wounds that refuse to heal.
No longer a cop, close to washed up and addicted to pain killers, Max takes a job in Sao Paulo,
Brazil, protecting the family of wealthy real estate mogul Rodrigo Branco, in an effort to finally
escape his troubled past. But as events spiral out of his control, Max Payne finds himself alone
on the streets of an unfamiliar city, desperately searching for the truth and fighting for a way out.
Featuring cutting edge shooting mechanics for precision gunplay, advanced new Bullet Timer and ShootdodgeT effects,
full integration of Natural Motion's Euphoria Character Behavior system for lifelike movement and a dark and twisted story,
Max Payne 3 is a seamless, highly detailed, cinematic experience from Rockstar Games.
Developed by Rockstar Games for a seamless, highly detailed, cinematic experience
Advanced Bullet Timer and ShootdodgeT and Final Kill-cam mechanics for stylish shooting action
Cutting edge aiming, targeting and animation processes for precise, fluid gunplay
A dark, twisted story chronicling the return of Max Payne, one of the most iconic characters in videogames
Tight integration between Natural Motion's Euphoria Character Behavior System and a brand new iteration of the Rockstar
Advanced Game Engine (RAGE) for lifelike movement and a new level of environmental awareness
A wide range of weapons rendered in incredible detail: hammers cock back, shells eject from the chamber and each bullet
is individually modeled from the split second it's fired to the moment of impact
Advanced particle physics and destructible environments set the stage for dramatic and chaotic gun fights
New to the series, a compelling and addictive multiplayer experience to  match the dark and relentless atmosphere of the single-player game.
SYS REQ:
System Specifications (Minimum - Maximum hardware tested at time of release)
Operating System:
Windows 7 32/64 Service Pack 1, Windows Vista 32/64 Service Pack 2, Windows XP 32/64 Service Pack 3
Processor:
Intel Dual Core 2.4 GHZ - i7 3930K 6 Core x 3.06 GHZ / AMD Dual Core 2.6 GHZ - FX8150 8 Core x 3.6 GHZ
RAM:
2GB - 32GB
Video Card:
NVIDIA® 8600 GT 512MB VRAM – NVIDIA® GeForce® GTX 680 2GB VRAM / Radeon HD 3400 512MB VRAM - Radeon HD 7970 3GB VRAM
Sound Card:
100% Direct X 9.0 compatible – Direct X 9.0 compatible supporting Dolby Digital Live
HDD Space:
35 GB
DVD Drive
Other Requirements:
Initial game and DLC activation requires an internet connection.
Max Payne 3 PC requires the installation of software and components including GameShield
IronWrap & Patcher;DirectX, and Microsoft’s Windows .NET Framework, and
Microsoft Visual C++ 2008 SP1 Redistributable Package (x86).
This release without crack.
Download & gain time before crack out.
Mount or burn & install the game
Apply crack when out & play the game.
LANG: ENG
SUB:  FR,GER,IT,PL,POR,RUS,SPA
Down it or w8 scene choice up to you.
תודה.
אבל היה כדאי שהיית מציין שאין פריצה עדיין.
צפה בהודעהelil, ב-31.05.2012 - 12:31 PM, אמר:
תודה.
יש שני גירסאות להורדה מה כדי להוריד ?
נערך על-ידי eL!RaN, 31.05.2012 - 12:41 PM.
צפה בהודעהeL!RaN, ב-31.05.2012 - 12:40 PM, אמר:
לא כדאי להוריד כלום.
אין פריצה.
צפה בהודעהelil, ב-31.05.2012 - 12:50 PM, אמר:
אין פריצה.
למה לא כדי אפשר להוריד ולהמתין לקראק וזהו למה לחכות ?
צפה בהודעהeL!RaN, ב-31.05.2012 - 12:57 PM, אמר:
אתה יכול לעשות מה שבא לך...
אולי יחסוך את הזמן של ההורדה בעתיד.
אני אוהב להוריד גרסאות יחד עם הקראק בשביל שיהיה בטוח מתאים.
גם ככה לוקח שעה להוריד עם המהירויות הורדות הגבוההות היום.
צפה בהודעהelil, ב-31.05.2012 - 13:03 PM, אמר:
זה אותו הדבר אני מבין בזה לעומק !
  • 1996 הודעות
יש לי את המשחק ל-PS3 , משחק טוב, מלא יריות חחח
צפה בהודעהIMAGINE, ב-31.05.2012 - 13:25 PM, אמר:
כן אחי קיבל ציון 9.2 בגיימפליי
עדיף לחכות לגירסא רשמית שתצא עם פריצה.
צפה בהודעהSkullHunter, ב-31.05.2012 - 14:45 PM, אמר:
זה גירסא רשמית יגנוב חחח
הקראק יוצא וזהו
הינה ירד לי אני מתקין
נערך על-ידי eL!RaN, 31.05.2012 - 15:21 PM.
התכוונתי שיצא אם פריצה,כי יש פריצות שמגיעות אם התקנה שונה ..
דרך אגב,אתה יכל להביא לי קישור לרקע שלך ?
צפה בהודעהSkullHunter, ב-31.05.2012 - 15:29 PM, אמר:
http://www.myg.co.il...c=phpQuaDyI.jpg
אבל הפריצה היא תתאים גם לגירסא הזאת
סבבה,נחכה לפריצה ונראה :)
תודה על הרקע .
צפה בהודעהSkullHunter, ב-31.05.2012 - 15:33 PM, אמר:
תודה על הרקע .
בכיף אחי
 OrHav
OrHav
  • 22 הודעות
משחק קטלני, תודה על הפרסום.
 super123
super123
  • 328 הודעות
    • מונה תודות: 9 תודות
8
אהבתי תרקע.. לקחתי :)
המשחק נפרץ , יש קראק ועידכון !!
דרך אגב,מי שהוריד את המשחק (אלירן) בגירסאתו הרגילה זה יעבוד לו .
נערך על-ידי SkullHunter, 01.06.2012 - 12:11 PM.
צפה בהודעהSkullHunter, ב-01.06.2012 - 11:54 AM, אמר:
המשחק עולה עם הקראק אבל שאני נכנס למשחק ולוחץ בכניסה אנטר הוא נתקע על לאודינג שעות הקראק דפוק לגמרי אני צריך לחכות לגירסא של רלואודד וזהו
